wtf crank?
KevinBoosted
129
Apr 13, 2008
Glendale, Arizona
So balls deep in an overhaul on my 2g when i noticed a bolt off my crank is sheared off :ohdamn: WTF? only question i have is since the head got sheared off the bolt and the rest is still wedged in there, can i just get it drilled out and replace it? im really not looking to pull the motor right now. ill post a picture in a lil bit
-Kevin
Depends what bolt your talking about, if its one for the harmonic balancer, then yes is possible, but I highly doubt you can drill out a flywheel bolt.
its 1 of the 4 off the harmonic balancer
negatory, im not disassembling the motor :thumb: and drilling thru the center of the wedged bolt and backing it out would not cause any off center holes
What i'm saying is a machine shop will not touch a failed home extraction most of the time. If the hole isn't drilled in the exact center of the broken bolt, it causes the extractor to break. You don't need to disassemble the engine to get the crank out either. Which bolt is broken?
I had one of those bolts break off before. Luckily there was still bolt protruding. I used a pair of pliers and it came right out. The bolt was not seized up at all. Maybe yours won't be either.
Invest in a set of "Easy Outs". They aren't cheap but they are nice to have around. A small set will knock you back like 100 bucks. They are worth it.
Take the crank to a machine shop before you drill any off center holes, or break a bit off.
I second this motion amigo. Especially if you're into the car that deep already. Why go through all the trouble to redo it just to skimp out on one piece that will 99.9% end up costing you more down the road? Trust me, been there, done that, lost a couple of pints of blood over it, never again.
If anything, just see if it's loose, and you won't have to yank the motor. But if it isn't, well, get 'er done right the first time. No one likes to fix mistakes a second time around.
nightracer91 Those bolts arent even part of the crankshaft, those are in the sprocket for the t-belt...
This is True. Take your t-belt off to extract if you are that worried about it. Just use a left a hand thread drill bit and get it out.
Hell its probably not even tight. Try ceter punching it and drilling it out with a left handed drill bit. Worked the one time I messed up and broke one.
Sent from my Droid
yea they are in the sprocket but how do you think the sprockets attached to the crankshaft? the bolt is too far broken off that i cant grab it with anything. im going to have my buddy from the shop come and take it out and put a new one back in. dont see why it would do damage, the sprocket was holding in with just 3 bolts for god knows how long at 25 psi on a 30r. only planning on running my 7 bolt for another year or two anyway before i yank it all out for a 6 bolt and its not my dd :thumb:
The sprocket is attached to the crankshaft by the large bolt/washer that go into the nose of the crank. The 4 bolts that hold the harmonic damper on just go into the sprocket. I've had a few of those break off before. I just pulled another sprocket out of the misc parts bin.
do you have pics of this large bolt/washer ? all i did was take off those other 3 bolts and the harmonic balancer came right off
Right those 4 little bolts take off the balance. But to get the timing belt sprocket off it is the big @ss bolt in the middle. The one that sits right between those 4 little bolts. You wouldn't have to touch it to take of the harmonic balancer.
That's pretty much what they're driving at. But, you'll have to do a timing job at the same time. You don't have to replace everything, but you'll have to at least rip it all apart so you can get to the tensioner. And at that point you should just go ahead and put in all new OEM timing components.
Or just run it with three bolts. It'll be fine with just three. Not advisable, but it'll be fine.
was already planning on doing a timing belt anyway but everything else should be fine. picking up a set of east out bits tomorrow and im getting this damn bolt out! while were on the topic of belts, anyone know if now since i ditched my a/c can i get the alt relocation kit and fit it back there since there will be no pump there and will the alt use the old a/c belt? or how is this going to work?
Before just purchasing the first set of Easy-out's you see, I would suggest checking these out. I have had this set for a couple years now without one tool breaking, and it was well worth the money if you are going to stay in the DSM game as this is likely not your last broken fastener you are going to deal with.
I have found an excellent bolt/screw/bit extraction set to be the Irwin 3101010 48-piece extractor set. The set is a bit pricey, but it is an invaluable tool to have. Expect the low side of this tool set to be around $190.00 if you are looking for deals. If you have a friend in the tool dealing business you can get a substantially better price.
As for taking care of the broken fastener, I would pull the crank sprocket off and remove the broken fastener, or replace it with a new sprocket.
Here are the new Mitsubishi OEM part numbers for replacement parts with list prices:
Crank Pulley Bolts (x4) - MS240211 ($1.22 each)
Crank Bolt (x1) - MD074255 ($5.43)
Washer for Crank Bolt (x1) - MD012455 ($17.50)
Crank Sprocket (x1) - MD326852 ($43.50)
These are list prices, so if you get a discount at a dealer, it will be lower than these prices. Otherwise, order them up through a place like JNZ Tuning.
thanks man i appreciate the part numbers, that helps. im probably not going to spend $190 on a easy out set but i appreciate the info. found a nice set of craftsman for $20.
I use the irwin extractors myself, and can say they are priceless to have. I don't usually use the extractors you need to drill a hole for, but the ones that are basically a socket with back facing teeth are awesome for removing bolts/nuts with rounded off heads. As mentioned above, a good set of extractors are a great idea, if you plan on sticking with 12-20 year old cars.
You will break the Craftsman set the first time you use them on a stubborn bolt. They are junk and are not covered under the breakage warranty.
The Irwin ones ARE fully warranteed when you get them through your Snapon, Cornwell, Matco, etc. tool dealer and are well worth it. All the drill bits from 3/32nds and larger along with all the extractor bits are fully covered for life. It is well worth the small investment. I paid around $110 for mine cash from my Cornwell dealer. Absolutely worth every penny.
If you want to go the cheap route, go and purchase a new crank sprocket and be done with it. I think it is around $32.00 before tax with my discount, so if you do a bit of shopping around, like I said, you will find a great price on it. JNZ has very fair prices on OEM parts and are still around 25-30% below list price.
