wtf crank?
bolt is out, thanks for the help everyone now to finish r2ing the water pump, man what a pain in the dick to get to. tensioner pulley is off but im guessing i gotta take the tensioner and all other components out of the way too. probably would have been easier to just pull the motor. anyone know if the balance shaft sprocket needs to be taken off to finish the water pump?
No, you don't need to pull the balance shaft sprocket at all. Just the 5 bolts that hold on the water pump is necessary, then clean the front cover surface and remove the water pump gasket material, then pull the water pump, replace the o-ring for the main water pipe, replace the water pump gasket, reinstall the pump and 5 bolts with the alternator tensioner bracket, and continue with the rest of the project.
you make it sound easy, the bolts are under this mess though
You will break the Craftsman set the first time you use them on a stubborn bolt. They are junk and are not covered under the breakage warranty.
Ive used them successfully at the dealership I work at without a problem (many times, never broken) and the package of mine do say they're covered under warranty... I purchased mine about 6-7 years ago. :thumb:
You need to pull the timing belt off and any components in the way to pull it. This is the main reason it is suggested to do a timing job if you are doing a water pump or do the water pump if you are doing a job -- that and it isn't a fun job to do twice.
