soldave
- 737
- 2
- Feb 17, 2008
Okinawa, Japan,
Asia
As you know, warm weather affects the power on our cars. Higher temperatures lead to more engine knock, and when the MAF detects overly high intake temperatures it tells the ECU to takes a degree or 2 of timing out, slowing you down (I am led to believe). And it doesn't get so much hotter or humid than in Okinawa. At the moment we've got temperatures of about 95F with about 80-90% humidity which is on the warm side! And I reckon it could be affecting my car's performance. Doing some logged testing on Saturday, I was starting the runs with an intake temperature of about 125F, dropping to around 109F at the end of the pass, as recorded by the MAF sensor. I have meth injection which will offer some cooling to the eventual air going into the engine, but that's going to be much higher after being compressed in the turbo.
So I'm looking to try and decrease my intake temps somehow. My engine bay looks like the following:
Due to the nature of the pipework, I can't move the intake and it's not economically possible for me to get another intake at the moment. I have a very cridely made cold air feed going from the driver's side air grille at the front to the engine bay pas where the resonator box used to be. The only idea I currently have is to make a simple air box which will probably have to curl around my catch can (see below for a closer look). It won't be great though due to the positioning of the air filter.
Wondered if anyone else had any other ideas for getting cold, or rather cooler, air to the air filter and getting my intake temps down a little. I also thought about the vent on the bonnet that is above the air filter, but not so sure how it can be used.
