ThomasG-1b
- 54
- 1
- Feb 21, 2010
madison,
Wisconsin
I did a boost leak test and came up with the tb shaft on the back side where you hook up the throttle cable is leaking alot of air. No where else though.
How would I go about fixing this??
I have my fan hooked up to a toggle switch so it runs. The other day it must of grounded on itself cause it melted. I got the car home(just dont have a fan) but now my temp gauge goes all the way too hot, before i even start the engine. It jumps around some too. I know it cant be that hot when the car didnt even run for a whole night.(car sat overnight and when I went to start it for work I had this problem) Any thoughts as why?
How would I go about fixing this?? I have my fan hooked up to a toggle switch so it runs. The other day it must of grounded on itself cause it melted. I got the car home(just dont have a fan) but now my temp gauge goes all the way too hot, before i even start the engine. It jumps around some too. I know it cant be that hot when the car didnt even run for a whole night.(car sat overnight and when I went to start it for work I had this problem) Any thoughts as why?
