2G Convertible Top Won't Respond
Pablobtown
108
4
Sep 16, 2013
Bloomington, Indiana
I have an issue with my convertible top on my GS-T. When I press the switch to move it, all I hear is a bunch of loud relays behind the back seats clicking and nothing happen. Both going up and down. It used to be to tap the button a couple times then it'll go. But now it doesn't work at all!!! :banghead: I switched the switch in the back to manual so I can at least push it down myself. But thats annoying and takes time. Anyone know whats going on here? Thanks for any help in advance!
Same thing happens to every Spyder owner. The motor probably did not burn out, it is more likely the shear pin broke. You'd think you would hear the motors running, but they can be hard to hear behind the panels.
Remove your rear side panels, and have a friend operate the dash switch while you hold the motor casing. You will feel the motor running if it is the shear pin.
One of our shear pins broke and partially came out. It jammed the gears so that the motor was not able to overcome the friction, so at first it seemed the motor was burned out. When the shear pin was replaced, the motor worked fine.
Burned out motors and broken shear pins are two different problems. I am suggesting to the OP to check the motor for spinning first, and a broken jammed shear pin second. New motors aren't as cheap as a shear pin, and, if he doesn't know what to look for, may experience the same problem with a different motor.
A shear pin is a small, strong post of metal, about the diameter of a coat hangar. The shear pin needs to be very strong, so don't use any kind of wire, go get a shear pin (make it at least 4 pieces when you find them so you have some on hand). You will need to go to a hardware store, or online, or dealer to get one. But, as you now know, they are a crucial part of your top system.
  • Wanted 2g WTB - 2G Cluster
    Looking for a donor 2G cluster for a project.
    • rwmagee90
  • For sale 1g 1g FWD 3speed design scattershield
    1g fwd shield
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $35 each. Message 702-741-6987.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale Cts-v calipers+rotors+adapters
    1g/2g CTS-V calipers cobra 12.99” and ctsv adapters, $650 plus shipping&pp fees text me if you...
    • Fully built dsm
