Compression testing question
coolrider2112
83
Jul 25, 2011
Sierra Vista, Arizona
Ok I am doing a compression test and my results for all cylinders are getting around 120-125psi I have been doing the test by myself since the gauge on the compression tester should hold. I decided to have my wife to crank the car while I watch the the gauge on the tester. I noticed the needle in the gauge bounces to 150-155 and then goes down to 120-125psi, I have tighten the hose in the spark plug hole as tight as possible, does this mean I have a leak on my tester somewhere or what? (It does really bounces to 150-155 psi on like the first few cranking revolutions and then it just goes to 120-125 psi. Thank you for any replies on this.
Yeah I's say your gauge on the tester is malfunctioning. It should hold the highest number it reads and only drop back down maybe 1 or 2 psi before it catches the needle.
Did you remove all 4 spark plugs,make sure car is not getting fuel(take out the mpi fuze), and give it full throttle while cranking it over about 6-7 times? Compression should hold on a stock 1g 150 unless your rings are warn, if you see it dropping from 150 that most likely means your tester is broken.
i would get a better tester and do a leak down test. My gauge is apparently not that great. I did a test and only got 120 on a brand new build. All 4 matched so i wasnt that worried. I did a leak down test to be sure and it was less the 2%.
