1G Competition Clutch Stage 3 issue
turbotom
120
42
Sep 27, 2003
New Bedford, Massachusetts
I recently installed a Competition Clutch Stage 3 clutch kit (part #5048-2600) with a new master and slave (1g 92 Eagle Talon AWD 5spd) Clutch will not disengage allowing me to shift, adjusted pedal (maxed out throw) and used a custom extended rod that gave me another 1/4 of inch which barely disengaged the clutch where the pedal height is right at the floor. I'm thinking I have a issue with my master maybe not be correct for the car seeing that the part is from O' Reilly's AutoParts and the adjustment rod isn't long enough 🤷🏻‍♂️. I got this clutch from a friend that we swap parts and is brand new in a box. Has anyone here have this issue with Competition Clutch like that before? This is my second clutch with CC on 2 different cars and the last car was totally fine with no issues but different stage (stage 2 I believe). Lmk, thanks for you help guys.
I mean there's your problem. Master cylinder should have a 5/8 stamp on it, indicating piston diameter. Compare the bodies and stamps with your OEM one you took off. If they are the same, you can simply swap your OEM rod on the new master. There is a circlip you can pry out and the rod comes out. Clean it from the old grease and put it on the new master. Then adjust as per the FSM. Did you resurface your flywheel and check step height?
Try reading this.
This could be anything from your clutch pedal assembly, bad master / slave, improper adjustment, air in system, mixture of air in system with improper adjustment, flywheel step height, wrong master cylinder bore, bent clutch fork, etc.
This doesn't sound like the clutch's fault unless it was installed improperly as well.
Ok I'll double check to see if it's says 5/8 seeing when I bought this car it's literally had nothing and was basically a shell of a car so the stock master was missing.
Also not sure if the part (Clutch Master) they gave me would be adequate and correct for my car which I would have to look into it. 21 years dealing with clutch issues with these cars I'm just probably over thinking it but I was curious to see if anyone had a issue with the clutch I was using and maybe there is something I over looked.
I always suspect flywheel step height when everything else checks out.
Yeah it's stock that I had resurfaced and unfortunately I didn't check the step height which could be a issue for me but didn't think it would be that far off to the point if won't go in gear. I was just trying to put the car together quick and used whatever resources I had laying around because it's a project that I'm building using very little money to do oval spectator drag racing with so I was trying to keep the cost down so I down break the bank seeing I'm upgrading my drag car 😔 That's DSM life for you🤦🏻‍♂️
I figure I ask because I was using ACT for 3/4s of my years working on DSMs which I started to venture off to other brands and found some of these companies had a better pedal feel unlike ACT with their "leg day" work out gym clutch pedal 😆 Not only that, some of these companies have better torque rating with a better clutch pedal feel so naturally getting older and wanting more holding power with a better feel made more sense to me 😆 I was so used to ACT and their "tricks/life hacks" to get them to work so I got to wonder if Competition Clutch had the same issues or someone had the same issues.
Here is my long rod I made for the master, hopefully I can get it into gear without grinding and the pedal height not down to the floor to at least move it around because pushing a dead car sucks 🤦🏻‍♂️
5/15/2024 Update on the Comp Clutch:
All I can say is 🤔.......... I HATE IT WITH A PASSION!!!!!!! It's no different than a ACT 2600 clutch and to be honest it is a 2600 pressure plate. I'm no longer a spring chicken and driving this car daily with this clutch with bad knees (I need both knee replacements) is driving me insane. I can't wait to rip this thing out, and if I continue any longer it will ruin this transmission due to poor disengage even with adjustments made etc etc. I did every old trick in the book but it's still awful, I'm done with this clutch.
So I inquired a Spec Clutch Stage 2+ with a Kevlar disc I'm willing to experiment on as well as a Action Clutch Stage 3 (I believe), with a 6 puck sprung disc which I have driven multiple DSMs with that clutch with great results and a nice manageable clutch enjoyable enough for street driving. South Bend I know for a fact is really good, installed that in my brother's 1g awd and loved it. So I always have a clutch to fall back on when I don't like this other brands. I will have to see what works good, I'll keep you posted.
The master is the problem. I literally just fought with this in my DSM. Only thing that solved it was going to an actual OEM Mitsubishi master cylinder, AND OEM slave. Now it disengages properly and the clutch pedal is more than just an on/off switch.
I have the southbend SS plate w/ B-series full face ceramic disk and love it. But I had the exact same issue until I replaced the parts store master w/ new OEM master. Fixed the problem after adjusting it properly with the stock length rod. Going with a longer rod or modifying the clutch pedal would give me even greater travel/control.
