comp cams 101100 or 101200
krummel21
497
May 4, 2004
Charles City, Iowa
With the add on's that I have listed in my profile would comp 101100 be the best cam set for me, or should I move up to the 200's. I don't plan on upgrading the turbo, also will I see big horsepower gains if all I do is switch out the cams. How much did you spend on yours too.
Thanks
I would think you would see a nice gain with the 200s as you would with the 100s. Your best bet is to go with 200s though. They are bigger cams and will provide a more efficient powerband as opposed to more low end torque with the 100s. I don't have a lopey idle at all with them either. Either way, you can't go wrong.
I run the 200s, dropped straight in with no cam gears, and the car actually felt much quicker. I don't know what to compare it to since I basically did a turbo one week and cams the next but it was quite a noticeable difference.
Go with 200s ive had both 100s pull hard till about 5800 rpm .200s pull hard from about 4000 to about 8800
200's i also have them, and i love them. Idle like stock, and pull well past redline.
