Clutch switch question
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Hooked up NLTS wire yesterday. Didn't work correctly. It acted as a rev limiter even with the clutch not pressed in. Couldn't rev past 5750 where it was set at. Checked my wiring and everything is correct. It also wouldnt disengage the cruise control when pressing in the clutch, ir would just rev the motor up.
Im thinking I have a bad Clutch Switch, my question is basically when the clutch pedal is depressed the switch should go into closed mode and pass along the ground to the ecu?
So there is no actual power wire going to or from the switch, only a ground? I unscrewed the clutch switch and took it off. With the key on and a test light hooked up to a power source and poking the switch harness's black wire the test light is grounded and the light comes on. When poking the green wire to the ecu the test light will not come on. Bad switch?
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
