bad clutch switch?
boostront
49
May 3, 2009
union, Missouri
To make this short guys.... My nlts recently stopped working. When its enabled it just holds rpms at 3k at wot and steadily builds boost. Car runs fine with it disabled.. Also clutch switch shows on log to always be -1... Has anybody ran into this before.. P.S. I re wired it since the problem but have still had no luck...
Thanks in advance guys
You should be able to go into further testing on the clutch switch. it should have a ground, and also a voltage signal to it. I would have to get the diagram of the circuit, but I would get in there and start testing.
Does the starter engauge without the clutch depressed? If the switch is working properly you should not be able to start the car without the clutch depressed.
