weith1111
- 1,182
- 52
- Aug 7, 2002
Wheaton,
Illinois
So I'm sitting at a red, goes green, press the clutch pedal down and hear a SNAP from around the pedal area, feel it in my foot too, and now the clutch pedal is a lot lighter. Almost crap my pants, but it goes into gear, engages and I take off. I limp it home trying to not use the clutch as much as possible.
I inspect:
pedal/assembly-don't see anything wrong, when i push the pedal with my hand, even 1/8" the rod starts moving into the cylinder or diaphragm on the firewall
slave cylinder-rod isn't busted/bent, no fluid leaking
It was close to the low line on the reservoir, so I topped it off and will bleed it today, which will hopefully bring the engagement off the floor. I can see the rod is only fully extended/fork bottomed out, when the pedal is to the floor. First gear is a little rumbly getting going, but the engagements into every other gear are pretty smooth.
If the bleeding works I'll be happy, but that SNAP still has me concerned.
Any ideas what else to look for? I figured it was the pedal assembly but was under the impression if it wears/breaks the pedal will move at times without actually pushing the rod. Mine seems pretty tight.
Where did that clutch fluid go? I'm not leaking any, nor have I ever.
I inspect:
I'm waiting on one of my friends to be unlazy enough to come over and hit the pedal a few times so I can check for flexing and bleed the clutch. You all have good input and I will check out everything suggested, with removing the pedal assembly being last, of course (being the hardest). I double checked the spring again and everything looked in it's place. The snap I heard is leading me to believe the assembly is screwed up somewhere.
, my clutch pedal felt really soft and the shifting was notchy.
