Clutch in = Car stalls...
my98gsx
Supporting VIP
794
290
Aug 14, 2005
Wappingers, New York
Ive checked the forums over and over and i found alot of posts telling problems that people have had. My problem is, none of them fixed my poblem. I can operate alriht untill the car warms up and then when you put the clutch pedal down the car will choke itsself out and stall. This is what i hav checked...
1) Clutch has been in for over a year and engages properly.
2) Ive grounded the throtle body to the firewall
3) Checked connecters to iac and tps.
4) Advanced my timing
5) Adjusted my tps
6) Checked fuel pressure
7) Raised my fuel pressue
8) Raised and lowered my afrs from lean to rich
9) Checked for vavume leaks
10) Raised and lowered my tbody bliss screw...
Anyone who has this problem, how did yu fix it??? what am i missing? :banghead:
I had the same problem. But it was when i put new motor in i had the safc2. I had no idea what was wrong i replaced iac motor. so i took it to extremotorsports they said every time i was hitting clutch the afc controller was trying to reset it self so i had the car tuned and never had problem again
Have you had your battery disconnected?
My car did the same thing after I had disconnected the battery and let it sit. It would start idle and run fine until it got hot. Then when the clutch was pushed in it would act like the idle was too low and just die.
Solution - I drove it about 100 miles once the computer relearned the engine it was fine.
Is your BOV recirculated?
