1sick91tsi
- 149
- 1
- Feb 13, 2004
pipersville,
Pennsylvania
Ok well heres the thing, I had a bad clutch pedal assy. so I changed it out, while I was there I did the master cylinder and bled everything and the clutch seemed good. Now the assy. that I got has the smallest about of play in it, the kind that mean its bad, push it in pull up and theres a tad of movement. Now I mean like a quater of an inch of play. My question is that when the car first starts up and I start going every thing is good, clutch free play is there, engauges at the right time, and trans shifts great. But after say 20- 25 mins and a bunch of shifts later the free play is gone the engagement height is much higher and the trans will grind second quite a bit. What could the problem be? Just a simple bleed the clutch or maybe a whole new pedal assy.? Any help is appriated. thanks guys.
