Clutch + Flywheel combination help!!!!
ClassicalBor
158
Feb 9, 2006
Baltimore, Maryland
So i had a standard oe replacement style clutch from napa on my car and it couldnt handle the torque in the higher gears and would slip... so they are letting me upgrade to a stage one performance clutch, My question is... would the flywheel that they put in with the first clutch work alongside with the stage one performance clutch or would i have to get a lightened flywheel with it? :confused: Heres the specs:
FLYWHEEL (currently in car)
Item#: NNC605603
Price: $279.00
Attributes:
# Flywheel To Crankshaft Mounting Holes:7
# Flywheel to Pressure Plate Mounting Holes:6
# of Teeth:110
Flywheel Step:.610"
O.D. Flywheel:10.320"
Stage 1 Hi-Per Clutch
Item#: NNCF1122
Price: $314.00
Attributes:
# of Splines:20
Additional Contents:Clutch Disc
Cover Assembly
Release Bearing Assembly
Alignment Tool
Clutch Size:225mm
Cover Type:Diaphragm
Disc Hub I.D./Input Shaft Size:22.4mm
Disc Material Type:Carbon/Kevlar
Will this high performance clutch work with the flywheel listed and not cause me any serious problems basically is the question. I dunno if that helps you out any :) but the flywheel isnt lightened its an OE replacement basically i think. All parts are from NAPA.
Thanks unknown, yeah that fly is brand new anyways.
Ima given my mechanic the ok tomorrow to order the stage 1. Luckily they are only making me pay the difference between the stage 1 and the standard.. and only 100 dollars labor... company is covering the rest so i think thats good
