2G clutch adjustment?
kisom2173
45
Jan 23, 2012
IDK Fort lewis, Washington
Changed out slave and master had the tranny drop and internal checked. Everything was fine. But clutch engagea dam near the bottom with the rod all the way out. Slave and master was cha ged out 1 week ago for the 3rd time to make sure it waant the issue. Now could it be thay the master is not oem? Any advise will be thanked. Also if i posted this in the wrong spot my bad, just let ne know.
Did you bleed the system right? you might have air in the lines since you changed things many times. Another thing, your clutch fork where it meets the slave, could have been put on too far from the slave so when you bled the system it had to have been bled a lot to make up for the distance the slave has to travel to engage the fork.
Ill try to bleed it again
