clutch adjustment back to stock
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
is there a way to readjust clutch pedal to stock? b/c i kinda mess around with it when i put in my new clutch and i think it's way off or something. now the shifter wont give me first gear on a dead start, 3/5 time only if i'm rolling 15 mph to a stop while putting it in.
also i have to jam it in reverse to get it in or else i'll get 4th gear. it seems like the shifter is move all the way to the right.
thanks
thanks
As far as setting it back exactly "stock" Idk that you'll be able to do that since you've moved it unless you know how many turns you put on it
Go under the clutch pedal loosen the adjusted nut and screw in the rod...
The farther in the rod the quicker it'll engage. Just trial and error on adjustment.
I adjusted mine a good 15-20 times and its finally just right.
Also check fluid level too
