j-jamrod
- 83
- 1
- Nov 8, 2007
Baltimore,
Maryland
after i done mi head job and new piston rings, the cilynder #4 is dead, y replace the spark plug wires, the spark plugs, i interchange it to, change 2 set of injectors, check the compression and all cilynders are almos even 178 psi, checked the voltage to the injector plug and everithing is fine, the timing i checkes numerus times and is correct , but after all this the cylindre i sno working, somebody have an idea what could be is drivingme crazy, it no make no sense having all cylinder with the same compression and with the elctronics, and injectors replaced, HELPPPPPPPP
