[RESOLVED]number 4 cylinder not firing? (randomly)
boosted86
414
5
Sep 7, 2005
Weston, Florida
Ok, well i having this issue with my car and its really bothering me. number 4 cylinder will randomly not fire, its weird. i was driving today and all of sudden the car started to miss horribly, i pulled over and found out that number 4 was not firing. i removed the plug and and did a metal to metal test, and the fired. i re-installed the plug and the motor ran perfect. this has has happened 3 times today and each time its the same thing(removing the plug and re-installing the plug...working) i changed the plugs and the wires and the problem persist. note/ the transistor is new. thank in advance.
sorry im not sure if its a coil pack or dist cap and rotor? but is so check the rotor/ dist cap for wear/ corrosion, and if its a coil make sure you have power and check the resistance of the coil, could be faulty
I have a simular problem, last saturday returning home from Miami on I-75 we stopped at a resturant, when i started the car up it ran rough like one cylinder was not firing. I reved up the engine and it smoothed out.
Ok, I am in the same boat. I have this issue where my 1 and 4 piston will not fire! I thought it may be the coil pack as they both run off the same one, so I replaced it with the new coil on plug setup. I jumped in my car all excited like, started it... same thing! Where does the spark come from? I have a 95 Talon TSI. Is it the Crank Position Sensor? I don't know where to go from here!
