check engine light on under throttle
climaxspanky
Dec 8, 2009
climax, North Carolina
just hooked up dsm link have been having problem with the car not making boost after i hooked up the link my check engine light comes on under throttle. here is a copy of the log mods are big 16g walbro 255 fmic and hard piping dsm link
Sounds like dsmlink is setup for you to see knock on your dash with the CEL. So if your getting detonation then it may be that. I cant read logs on my phone so I cant do that. Do you have a wbo2? Have you setup dsmlink for you injectors, year car and maf?
the car is a 91 eagle talon. i still have the 1g maf i do not have wide band o2. i have not set up the injectors with the link yet just put in car and seen the check engine light on under throttle. something else i dont know about is i have aem adjustable cam gears and they are set on 4* btdc that is what they were on when i got the car is that fine i am also waiting on aeromotive afpr
    • george bromwell
    • pma1123
    • Sdcryan1
