Charging/electrical problems (I'm stumped)
jp171
758
Apr 6, 2003
Oakland, California
I've been here a while, but my car's basically stock and this is an issue with unmodified parts. That's why I'm posting this in the newbie section. I drive a 1990 TSi AWD with only an ACT 2100, K&N drop-in, free aircan mods, crushed BOV, and KYB GR2 struts.
Symptoms:
1. Vehicle does not hold charge. We've been driving it off the battery once a week or so to keep the powertrain from seizing up. Until a month or so ago, we were able to drive it until we drained the battery.
2. Now it won't start, when you try to start it, it just cranks and won't turn over. once in a while, when you let go of the key after it wont start, it sort of clicks/grinds very quickly for a few seconds.
3. For a few months before the charging problem surfaced, and every time it's been driven since, the boost limit has fluctuated wildly between the stock setting and what my seat-of-the-pants dyno says is about half of the stock boost setting. It feel like fuel cut (as experienced in other people's cars), but there's no way in hell such an unmodded car should be experiencing fuel cut. Therefore, I'm guessing the boost is being limited.
Things we've done to attempt repair:
1. Purchased new Duralast Gold battery from Autozone. It's been repeatedly tested as being good as new by Autozone, two competitors, and a couple shops.
2. Purchased "new" (remanufactured) alternator from Autozone. This has also been tested as being good as new by Autozone, the same two competitors, and the same couple shops.
3. ECU removed, disassembled and visually inspected by myself and my brother for leaking capacitators. We see none, but we're no experts.
4. Battery cables and nearby wiring checked. No shorts, cuts or holes in insulation found.
Anyone got any theories? Ideas?
When responding, please keep in mind that I make $6/hour, and I'm limited by bills. So please don't tell me to have it towed by a Range Rover to some megabucks specialty shop. If I could afford to, I'd just take it to Buschur, since they do excellent work at fair prices, but I can't even afford that.
can you push start your car. I see you have an ACT 2100 so I know it manual. After getting it started, take it too autozone and see if they will bring out their tester and test it underload while running only. Dont shut it off or you will be pushing it out of the parking lot. IF all checks out okay, get it home and shut it off. Try to start it, if not, then it could be a few things. Checking the starter (the local autozone could do that for you, but you need to pull it out). Then check with a local DSMer or junk yard and swap ECUs.
Id figure out the starting/ electrical problems first then deal with boost related issue second.
With engine running measure voltage at the battery. It should be more than 13.5VDC and less than 0.4VAC. If not, either (1) your 100A fuse is blown, or (2) your alternator is still bad (it's not unusual to get a bad one from an auto store even when it tests so called "good" on their tester - example: their tester doesn't check AC voltage or with proper load), or (3) your battery just can't hold a charge, or (4) your connection between the alternator and battery is high resistance, or (5) you've got one heck of a load/short present, or (6) you've got a poor battery/alternator ground.
For a proper and complete test of an alternator take it to an alternator/starter only repair shop (see yellow pages - they will test it free). To test for battery drain: http://www.dsmtuners.com/forums/showthread.php?t=179481. To test grounds: http://www.dsmtuners.com/forums/showthread.php?t=179916. Good luck :thumb:
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
