CEL right after new plugs.
Colorado KID
Jan 30, 2010
Windsor, Colorado
Alright guys. So i've been looking around at some of the threads on the P0170 CEL and almost everyone assumes it is the O2 sensor. Here's my dilemma. I recently replaced the turbo with a FP Big T28 and a 1g Bov since the T25 went bad and i was blowing oil from the bad turbo.. After cleaning it all up, inter cooler and everything, i reinstalled everything. It ran fine except when i went WOT it lagged.. So i checked my plugs and man were they bad. Almost all of them were gapped at roughly .05.. I bought some NGK's and gapped them at .032 like my book says. It ran great for about 4 days without a CEL. No lagging on acceleration or anything. 4 days later.. CEL came on. Since i got the car, I've felt like it has been running rich. Exhaust smelt more thick compared to any other car of mine. More recently i have had black soot on the back of the car above the tail pipe. Old plugs were pretty fouled.. And some days there is a very strong gas smell outside the car after i shut it off.
Anyone believe that this is an O2 sensor still? Or could it be something else?
I don't have a data logger and i cannot afford one right now. Anyway for me to check these things fairly easy? I would assume that i would have gotten a code for the O2 sensor being bad if it was the O2.. but maybe i am wrong?
Dying / dead front O2 sensors report a voltage <0.5v to the ECU. This indicates a false lean condition, which the ECU tries to compensate for by increasing the ST and LTFT's. So, yes, a rich condition does point towards a dying front O2 sensor.
Do you have access to a logger so you can check the voltage? If not, you can probe the pinout at the ECU for the front O2 with a volt meter. It should be oscillating between 0.2 - 0.8v at idle when fully warmed up.
