CEL codes
4G Power
76
Sep 20, 2012
N/A, Missouri
Recently my car started running really rich - like 11:1 while just cruising. I pulled the codes today, and I got these;
P0400- EGR Flow Malfunction (from my EGR delete, will hide once I install my dsmlink)
P0170- Fuel trim malfunction (bank 1) (bad upstream o2?)
P0141- O2 Sensor Heater Circuit Malfunction (bank 1, sensor 2) (bad downstream o2?)
P0125- Closed loop fuel control insufficient coolant temp
P1105- Manufacturer Control fuel air metering
Should I replace the upstream/downstream o2s? What about the other codes?
Thanks
Sounds like coolant temp sensor. If it is malfunctioning it can potentially do all sorts of weird things. I would start there first and see what happens. Make sure you clear the codes after you replace anything so the computer isn't compensating for something you've already fixed.
im getting the P0125 code too
i have a code reader so i pulled it out while driving the data on the coolant temp was 200ishF
is that low doing about 60mph on the highway, in about 40-55F weather?
