CEL codes
P0443 - EVAP System Purge Control Valve Circuit Malfunction
Check purge control solenoid, including vacuum lines. This is emissions related, it opens while your engine is running to purge your charcoal canister.
P1105 - Fuel Solenoid Malfunction
Check the Fuel Pressure solenoid, try cleaning it with electrical cleaner, reinstall, and reset the ecu. This is needed for hot starts.
Have you done the Taboo emissions removal, and forgot to leave the connections plugged in?
