tsunari
- 1,030
- 34
- Feb 12, 2003
Jessup,
Maryland
Ok . . . I know the Caster on the eclipses isn't adjustable . . . but how are we to know if it's out of spec? And if it IS out of spec . . . what needs to be replaced?!?
FSM says that the Caster should be [ 3.2 deg <-> 6.2 deg]
Personally, mine is set at [3.2deg -- Left] [5.7 deg -- Right]
Now I've heard of having the caster offset to compensate for the crowned roads here in the US, but a difference of 2.5 degrees?? I'm wondering if perhaps I might have something bent.
So . . . PLEASE- post your Caster settings so I can compare
I realise I'm within the specs, but I just have a sneaky suspicion that something might be worn/broken
Thanks!
Thanks!
