Car won't start
bartels903
2,052
Dec 3, 2004
Gahanna, Ohio
I just got done changing out the headgasket, my car won't start at all. When the key is turned the car will crank but not start up. I can't figure out the problem. I made sure all connections were together, and all lines back in place.
also another thing you should check is fuel and spark if you have fuel and no spark check your cam and crank sensors. with these cars if one of those sensors go bad it will kill the spark to prevent damage to the engine.
1- Compression Test since you changed the head gasket; (about $30 for the tester at any local parts store)
2- Check for fuel and spark
Fuel - Pull the spark plugs and check if they are dry or wet and if you can smell gas on them if no gas, refer to #4
Spark - Pull one plug at a time and put the end close to a metallic surface while keeping it connected to the wire and crank over. Check for spark. If no spark, refer to #3
3- Check CAM Sensor, CRANK Sensor, Coil Pack and Resistor Pack to make sure they are good and within spec and plugged in;
If they are plugged in, test the sensors and packs according to the service manual...I don't have mine handy right now but I can help you out if you need it.
4- Check the Fuel Injection fuse and make sure the injector connectors are plugged in
One of these should resolve your problem as that's what you need to fire up the enging seeing as it turns over.
Let me know if this helps out!
Grnchevyz summed it up perfect... I am guessing it is one of the sensors that went bad.
Compression 151-155-150-151
Fuel in fuel line, not going through injectors
Checking CAS tommorow, where is the crank sensor located?
Checking Fuse tommorow.
And for some reason when trying to crank my car over my timing belt is moving slightly off the cam pulleys, what could be the reasoning for that, tension to loose?
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
