car wont start or turn over, will pop start tho
nick585willey
63
Oct 10, 2012
perry, New York
okay so heres the deal, my 96 eclipse gs with the 420a engine will not start, i just replaced the starter because i thought thats what the problem was and still nothing. the car gets power, has a brand new alternator and battery and now a starter, there is absolutely nothing when i try to turn the car on just power to everything no sign that it even wants to start, i was thinking maybe its the asd relay but i cant be sure what do i do
seeing as the starter wont turn, check that your signal wire is getting voltage when the key is turned, if not, check your starter relay.
have you checked all your fuses and relays? get a piece of wire, strip some of the rubber coating off of each end (make sure its a thick wire, no speaker wire or anything like that), and connect the + to the + of the relays (most of them have a diagram on them that tell you whats what. Once you have the wire in place, try and start it, essentially what you are doing is sending the voltage through the wire to complete the circuit and thus acting like the relay.
If the car turns over then the relay is bad, if not then its not the relay.
