Car won't start cold
93AWDTalon1
175
Oct 15, 2004
Louisville, Kentucky
I can't get my car to start when it's 25-30 degrees outside I have to try for like 20 mins to get it to. Some times it acts like it 's firing and others not at all. Does anyone have any ideas on what could be causing this?
I am also am having this problem on my 1g. Is the coolant temp switch on the water neck where the thermostat is? Cause all of the wires are broken off, but my car starts after about 10mins of trying when it is cold outside.
It does matter on a 1g. Mine went bad last winter and it refuse to start up until after 15 minutes of cranking. You will only have the problem when it's cold out.
-Brian
Yeaup pretty much. The ecu doesnt know how cold or warm it is outside so its dumping a butt load of fuel which is overloading the engine not causing it to start. If you can get your hands on a logger and if your Coolant temp sensor is bad it will read really messed up readings like -72 degrees outside. The sensor is like 30 bucks from an autoparts store and easy to replace.
ok thanks
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
