echostats
- 158
- 0
- Dec 7, 2004
Massillon,
Ohio
Hey guys, after searching a lot on the forums I have decided to make my own thread. I took a video (it's sideways but it works, click the link).
As you can see, the cars seems to be hitting a low rev limiter or something.
Here's what I have done so far:
1. Checked for boost leaks, there are none
2. Tested ohms on injectors all the same (2.3), checked wires and replaced 7ES plugs
3. Checked waste gate
4. Tested TPS, set TPS
5. Checked o2 sensors
6. Checked fuel pressure
7. Checked the MAF connection
8. Replaced the CAS
9. Coolant level is perfect
10. Swapped ECU
Please help!
UPDATE: Not only does the tach jump when parked, but while driving the car feels like it's hitting fuel cut at 5k RPM (10lbs boost). It shakes wildly. I have checked the fuel pressure and it's fine.
8. Replaced the CAS
10. Swapped ECU
Please help!
