car wont idle...
ineedagsx
273
Aug 14, 2007
islip, New York
ok so my 95 gst has always ran fine but lately its just been getting weird. It started that if i was in traffic or anything the idle would just keep climbing and climbing until it would idle at like 4grand. i drove it the other night and it was making some weird noises when i got home. I went to start it and it starts up fine everytime if you give it gas but as soon as u let off the gas it dies... any ideas? thanx guys
How recently did you do a BLT and are there any CEL codes that need to be pulled?
If you have a multimeter you can do a few sensor checks, just to make sure everythings working correctly.
IDLE STEPPER CONTROL MOTOR (ISC)
Check resistance between the following pins, 28-33 ohms is good with ambient temperature at 70*.
  • 1 & 2
  • 2 & 3
  • 4 & 5
  • 5 & 6
ENGINE COOLANT TEMPERATURE SENSOR (CTS)
Check resistance between both pins on the CTS as the car warms up, as the temperature increases the resistance should decrease.
  • 32* = 5.9 kohms
  • 68* = 3.5 kohms
  • 104* = 2.7 kohms
  • 177* = 0.3 kohms
Post up your results and we'll go from there, odds are you'll find the problem though.
:dsm:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
