ECMlink Car won't idle after parts install
Myk984g63
5+ Year Contributor
105
34
Oct 8, 2020
Bakersfield, California
I've included a log when I try to start my car. Recently replaced head gasket and installed the following parts:
FP 68hta
Sheet metal intake manifold
850cc injectors
255 fuel pump
external wastegate
FMIC
The plugs and wires are gapped and hooked up correctly and all the connections in the engine bay should be correct. Please take a look and see if I've done something wrong. Im super excited to drive after these new parts to see the difference.
The car is likely running extremely rich. Dial down the deadtime to zero and start there. Also, your intake temp pin needs to be changed back to factory under pin assignments.
Change the intake temp connected sensor to Factory/none. And uncheck "Lock intake temp and baro pressure". Also don't forget to adjust the TPS properly.
