2G Car won’t turn over
Mikey_Dsm
69
27
Nov 1, 2021
Layton, Utah, Utah
So I’ve recently been trying to get my car running after it sitting for a year and it used to crank and start up easily before with no issues but now it’s not able to. I have replaced the head gasket recently.
The issue is when I try to start it, it makes a loud clicking noise but never cranks. But if I pop the clutch while moving it starts up easily. And then if I turn it off afterwards same situation as before starts up.
I’ve replaced the battery, and starter.
I can’t seem to figure it out, and from reading about others with this similar issue they said it could be the alarm system drawing power. And if that’s the case I don’t know what wire I need to find.
If not a weak battery or bad starter solenoid, then you most likely have a bad large battery cable connection. Disconnect battery cable terminals on both ends of both cables, clean them with a wire brush, and re-tighten them. Remember the large ground cable coming from battery negative needs to go under a starter mounting bolt head on the bell housing. A separate cable goes to the firewall.
Could also be a bad cable (eg. internal crack) which needs replacing.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
