2G Car won’t turn over after motor swap
99ECLIPSEGSXDSM
1,745
74
Aug 22, 2010
Erie, Pennsylvania
Hey everyone. I’ve been having a problem for awhile now. So I swapped my motor after it being down for a year with no motor in the bay.
Before when I lost compression, the car started on a dime and now it doesn’t make any noise besides the pump kicking on when I turn the key. No starter noise, no clicking, nothing. Starter was tested and I swapped a different ecu to see if that went bad, and still the same results. Dash lights up as normal.
I’ve taken the car to a friend who owns a shop and says all the resisters and fuses are good. I’m missing something a I’m pulling what’s left of my hair out! Please help
Check that the signal wire is on the starter, the small spade terminal. If that checks out, jumper that terminal to the starter HOT battery cable, that should most definately spin the starter. If that works but the key doesn't, you have a break in the signal wire from the ignition to the starter.
Hopefully you just forgot to hook that wire up.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
