Car still wont start.. HELP!!
Crazy91GSX
121
May 31, 2004
Lubbock, Texas
Hey guys.. I have a problem. A 91 GSX.. no start.. here is the info. Bent some valves, put it all back together, no start... The engine will turn over with ease. No pops, or any other odd noises. The timing has been set and triple checked, as well as a compression test.. which showed 120psi accross all 4 cylinders. The position of the CAS has no effect on the engine. I pulled the inlet off of the fuel rail, there is plenty of fuel. Pulled the return line off of the fuel pressure regulator, and plenty of fuel spurted. So, I took a test light to the injector clips, and all lit up just fine. Pulled each spark plug wire off one by one and each fired, plenty of spark. I tried to ground out the timing plug to the battery, nothing. All connections, lines, hoses, clips, etc are hooked up, nothing was left unhooked. Anyone have any ideas?? I am getting very frustrated!!
-The MAF is hook up right? how about broken wire on the harness by the connectors?
