2G Car starts, but 2 injectors not firing...
99GST83
73
Dec 17, 2008
Emmitsburg, Maryland
I just recently replaced my crankshaft position sensor, camshaft position sensor, IAC valve, checked resistance on all spark plug wires, 4 new plugs, and all 4 cylinders are getting spark (while engine is running, I can pull the boot off of the plugs and hear the "popping" of the spark on all 4 plugs.)
The engine starts up, but only runs on 2 cylinders. (sounds like a WRX right now) When I pull my injector plugs on cylinder 1 and 2, there is no difference. When I pull either 3 or 4, it chokes and tries to die. Timing is 100% on. All marks line up perfectly. Compression test confirmed that all 4 cylinders have great compression.
Any ideas?
I do not have a spare available. Nor do I know anyone else around my area with a 2g Eclipse
Just tested all injectors and injector harnesses. All check out good with mutlimeter.
Anyone else have any symptoms like this, and if so, what did you do to finally fix it?
