car shakes violently when at a stop in D
bo0st
835
24
Jan 26, 2010
Phoenix, Arizona
Hey guys please help, my car shakes violently when at a stop in D.
Mods are current in profile. Motor mounts recently changed. No CEL lights.
Brakes are new, so are tires.. Have no clue where to start here..
What is violent to you? My car feels like the end of the world is coming when im stopped and the cams are loping, but thats just me. To someone else, it may feel ok/tolerable.
What rpm is your idle at when in drive and stopped. Does it shake like that in Park?
Also, your nitrous, is it on a throttle switch? How is it activated?
Are your motor mounts polyurethane? It could just be the exhaust makes it feel like it shakes abnormally.
It's like someone is shaking me to death LOL.
RPM - 700 - 800, then it would rise to like 1100 - 1200 at the most as if I'm giving it gas and If I'm not HARD on the brake that baby wants to drive.
Nitrous is activated via throttle switch and only at WOT (wide open throttle) Haven't hit WOT In a long time trying to stay away from the speeding tickets.
Thanks for the fast reply.
No they are OEM autozone/oreilly one's
well you need to check all your TB sensors vacuum lines and i would seafoam your engine you broadly have dirty ignition. ive had a couple cars that ran like crap just because they ether didnt gap plugs right or it was just that time for a cleaning.
also clean your TB and MAF
Does it stop if you put it in neutral?
Yes it does stop when put in neutral. Does that help identify the culprit?
TB was cleaned as well as new plugs put in. Properly gapped too.
when you put the car in D it is applying a load via the transmission. id check for vacuum leaks and a properly functioning EGR, as well as cleaning out the map sensor port, and the map sensor itself.
also, do you have an codes? i would scan it to check, get back with us after all that.
Ok Im going to toss out a few possibilities, you may have to check some of these with a voltmeter (for sensors) or just replace entirely. This may not be the easiest issue to find, just a heads up.
Throttle position switch could be bad, I believe the TCU relies on the TPS to determine engine load and shift points? Is it possible the car is in a high gear at a stop due to misinformation from the TPS?
Bad TCU
Bad torque converter or the balance weights may be missing
The only reason I believe it could be something to do with you driveline is the fact that you've replaced all of your motor mounts and only get this vibration when the trans is engaged.
I am unsure if EGR issues would cause the 10.0 earth quake type vibrations your a describing.
Usually, if it vibrates that bad when stopped in gear, but stops when it's in nuetral (or park for A/T's), that would point to motor/trans mounts going bad. Simple problem to fix, and pretty cheap too. Suprised no-one else suggested this?
Because OP wrote this:
Granted he didn't explicitly say he replaced all mounts, but he did implicitly state it.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
