Car Overheated / Overheating / Overheats [MERGED]
NTRCOOL
Apr 10, 2002
OVERHEATING? The issues and their solutions have remained the same- either you don't have enough cool air reaching the rad, there's a cooling system obstruction which is preventing coolant from circulating, or your head gasket has failed and is allowing coolant to be consumed or pushed away from the engine.
Discuss all possible overheating problems and solutions here.
OK,
I just left my house to go over to my GF's,and happen to look down and see my needle right before the red mark. This just happened out of nowhere. I stop the car as quickly as i can, and pour in some coolant(Coolant a little low). Still same thing. Welp im in the middle of the road, and HAD to get it home. Im only 5 min from my house. I decided to try and make it(I really had no other choice). Welp I drive no faster than 20mph, and the temp needle is BARELY into the red the whole way.And occasionaly to the left of it. Am I ok?? Do ya think any damage was done?? And im thinking either thermostat, or water pump. For each of those, whats a round about $$ figure to get replaced?? Any info you have would be GREATLY appreciated!
@gstryyder Yes the fans come off and no i took the heat shield off. How would that affect temperature.
@DwrDsm how would I know if my water pump is bad?
The aluminum rad on the car is really thick, One of my friends said it could be overheating because the fans arent powerful enough to draw air through it, but it just started overheating and Ive had the rad on it since I bought it? I'll check the oil to see what it looks like and get back to you herms
did you do any recent work on the car before it started overheating?
im thinking poor coolant flow or inefficient coolant.
is the coolant fresh and clean?
do you have a 50/50 mix?
OK this morning I checked the antifreeze and oil and they both looked fine, no milkshake. Then I started thinking and a while back I had to replace my cam position sensor and I'm thinking maybe the timing is off. If the timing is off can my engine overheat? What should my timing be set at if everything on my engine is stock? Thanks a lot for all the help guys.
i had a coolant leak about a year ago. a mechanic shop said it was from the bottom of the radiator. But upon my own inspection it was the lower coolant hose needed to be replaced (not the radiator). if you are overheating rather bad another thing to look into is not necessarily that its leaking (unless you can clearly see a leak, or you always have to refill the coolant). Check your hoses with the car off for play. Squeeze them and see if fluid is moving. Obviously if you haven't yet, change your thermostat. i change mine out every year. But this last winter some of my hoses (more particular, the one from the thermostat housing to the coolant resivior) got clogged. When they clog or freeze it will overheat really bad almost instantaneously. Within 4-6 miles you'll be in the red. if you have ever tried any of those slop looking mud pellets for radiator leaks they might be the culprit. it turns to sludge and will cause a block. To fix this, empty your radiator and clear the upper and lower hoses out (or replace them). wash out the radiator with water and a hose. You can pay 100 bucks to have a shop do this for you "radiator flush" or save 75 bucks and do it at home. Your call. This may not be your problem with overheating, but is something you can look into.
^ Bandaid, no it isnt, it isnt a quick fix at all. He is tryin to say you can recieve better cooling if you could get more air to the Rad. Nothing about it fixing the problem, we should all know more air to a radiator isn't going to fix anything, just drops the temp some.
I would replace the cap and see if that helps. I think it might be your water pump. If you need more air to the radiator try making the scoop and make some duct work for the sides and the top and bottom. Do you have ac? And if so is it running while this happens. I think these are all good ideas and i would try them all they will only help you figure out the problem.
if it over heats while you idle more than likely your water pump, if it leaks around the cap or look at the cap see if it still has all the rubber to seal if you have a ir thermometer then you can point at thermostat and check to see how hot it gets before it open if it opens with the radiator feel for variance in the radiator if some spots are really hot and others cool to the touch then radiator is clogged and if it was your heater core you'd be leaking in the interior of the car
Iam losing coolant and my car is slightly overheating once i drive it for about 40min or more (The temp gauge actually just goes a quarter or so above the middle) then comes down once i let it sit and idle. Also there is a little white smoke coming out of my exhaust when i take off somewhat quickly or floor it. I checked my compression 180 across the board. Once the car is warmed up coolant starts to drip from what looks to be the water pump area. I dont believe it is the headgasket because of the compression test, but the white smoke? maybe water pump?
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
