2G Can't turn down boost
Mham2k
307
60
Feb 8, 2008
Dallas, Texas
Something is wrong, I just don't know where to start.
IR boost controller
2 Port Wastegate
ECMLink
So everything worked fine on my last build, the boost controller, ecmlink, wastegate ect
My wastegate pressure is 10psi, I have tested with no controller hooked up
When I hook up the IR controller it gives me all the boost. It won't let me turn it down.
I have ecmlink setup correctly, I know this because this same settings worked on my old build. Disabled error correction, enable boost control, both tables set at 0.
Where do I start? IR selenoid?
It's hooked up based on the VFAQ 2 Port diagram.
I don't necessarily see anything wrong your settings. Zero out your duty cycle table and go from there. Remember, your duty cycle table is what your car is currently setup to reference for boost. The boost target table is only used when error correction is enabled. I suspect your duty cycle is too high for what boost level you want. If zeroing out your table doesn't work then we know it's not the tune.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
