2G Cant install turbo timer
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
I'm trying to figure out how to plug the right wires for my turbo timer. It was already installed but the previous owner disconnected it and now Idk how to reinstall it. I got the timer to turn on but I can't change anything. It's the buddy club turbo timer that has the security feature. Did he also use a plug n play harness? I tried finding the instructions online but no luck
Ouch what a mess. Those line crimp things are really bad to use and ruin the wire. It could be that they arnt making contact correctly. The timer needs to be wired into the ignition and you don't want those wires coming loose or not making good contact. I would start over and solder/shrink wrap everything properly. Find the wiring diagram for a apexi or hks turbo timer for 2g should be the same. They do make plug and play harnesses for most timers out there.
It's really not a mess. I just pulled them out a little and theirs a place to tuck them in. I wanna remove this timer and use a plug and plug that my buddy giving me. I can't tell if this timer used a harness for plug and play.
