2G can't find a replacement cas pigtail for 98 head in 95 gst
shifty2006
145
5
Oct 15, 2012
lake isabella, California
I have been looking all over trying to find the pig tail or extender that let's me connect my cas plug from the right side of the motor to the left side that attaches to a 98 cas and haven't been able to locate it. Mine has too many solders from breaking to even count
I thought I had found one a long time ago but I can't find it now.. also I'm trying to figure out my intermittent cylinder 1 and 4 not sparking I've changed cas and even swapped coil and ignitor..
It sounds like all you need to do is just buy that 97- CAS plug, it will come with the seals and terminals. Just be careful what wire you use, it takes a small wire to work right with the seals on that particular connector.
well crap that wasn't my issue ive fixed the pig tail now so now I have swapped the cas, the cas pigtail, the ptu, the coils. I don't know what else could be causing me to intermittently drop 1 and 4 spark. unless both my ptu were bad but I pulled this one off a car that ran just fine. I guess ecu would be the next swap but I only have a ecu from a 99 gst with my 95 car and the 97 cas I have my plug wires inverted could I just run the plug wires normal and plug in the 99 ecu and it work?
    • george bromwell
    • pma1123
    • Sdcryan1
