2G 98 GST Spyder can't find a home for this vac line
T420A
Aug 14, 2013
Barnegat, New Jersey
I just dropped this engine back in after I overhauled it and I seem to be left with a vac line without a home. The line comes through the firewall behind the normal battery location and is quite long and needs a home :) anyone know where it goes?
My TB is also a bit strange in that it doesn't have a port p on it.
My 95 GSX has this same line but the engine bay is empty ATM and the TB from it has all 3 ports on it so it's of no help.
LOL I have been a probationary member for 2 years wow thought there would be a time limit not just post count :-(
Straight out of the Rules and Policies -1. Probationary Member (formerly known as New Member/Lurker status):
Everyone who registers on our site starts off as a Probationary Member. This title simply means you are new to the site and/or haven't contributed very much tech info to the site. You can view all public forums and Search for all the tech info you need. However, you will be limited to posting in the areas designated for Probationary Member posts ( you must limit your tech questions to the Newbie forum and Maintenance & Repairs forum) until you've met two milestones - 30 useful posts in the forums (answers to questions, links to answers, and/or other helpful contributions in the Newbie and Maintenance forums) and a minimum of 30 days registered on the site. Find plenty of unanswered threads here to reply to with helpful information. Only posts in the tech forums will be included in your post count. You can still send Private Messages to members in lieu of replying to their posts in forums you don't have permission to post in.
Now, do you have a picture of said vacuum line? Check out this thread, it has a vacuum line diagram in it that may be helpful.. Also if Im not mistaken you should also have a diagram on a small plaque on the under side of your hood.. At least I think I recall having one when I had a stock hood years ago! http://www.dsmtuners.com/threads/ta...ved=0CBYQ9QEwAGoVChMIq-zTlNrxxgIVF1yICh2_9wVL
OMG *BANGS HEAD ON DESK* I totally forgot about the windshield washers.... That has to be it... Thank you so much :)
Easy to forget about when there is no hood
