Can someone PLEASE help me upload logs???
93_GEE_ES_EX
138
Dec 23, 2002
Orlando, Florida
Can somebody tell me how to upload some logs i have on my palm?
The software im using is pocketlogger.I search but could'nt find anything.Thanks!
Well you have to Hotsync. Put the logger files into the computer and open it up with the MMCD tool.
I've also used the above mentioned software, and its worked perfect.
Let us know what your using for logging software, and we can better help you.
Good luck.
93_GEE_ES_EX said:
I d/l the MMCD and my datalogger is called pocketlogger.
Can i get more help?
What does d/l mean?
The pocketlogger I have from digital tuning doesn't use MMCD as far as I know.
You should have got software with the pocketlogger that installs on your compurter.
Once you've done your logs on the palm, you hotsync it to the computer. Find and open the log through the supplied software, which I can't think of the name since I'm a work, and then go from there.
I will be able to give you more help after I get off of work at 3pm.
i hope i get this right...
i see the files in one of my folders in my desktop.How can i upload it here?
Try double clicking on the file. If the computer can't figure out what program to use then you will have to open the program yourself and then open the file.
Did you buy this used or new?
I'll be able to tell you the name of the program in about 45 minuets.
i click on the file and this palm one quick install box pops up followed by a conforim add.
do you have aol or aim?my screen name is dominick0221
