Can I still run this clutch?
90-GST
106
Aug 15, 2008
St. Louis, Missouri
Before I pulled it, it was still holding strong. I want to use it so that I don't have to have the car down for longer, but I thought I'd get opinions.
I say go ahead and put a new one in. I mean you already have the trans out and a new disk is only a 100 and some bucks.
Nah this one is done,look how close the rivets are to the surface,you would be pulling this bi*** back down within months to change that clutch
Clutchmasters FX400 pressure plate with sprung 6 puck and bearing $388
Resurface stepped flywheel to .610" and replace dowels $110
Knowing your clutch is good for at least a few more 1/4s of a mile, Priceless.
I just had to do the same thing when I pulled mine to fix a leaky/cracked gasket on my rear main seal housing. I didn't expect to see my clutch two microns from the rivets, and the waiting was the worst part. Then CM sent me a four pad disk, and I had to wait 3 more days.
i would definately change it....IMO not worth dropping a tranny to change a clutch i couldve changed a month ago...but hey if thats your thing go for it...hell i would throw it in the garage for a back up
Probably going to take it to a local place and have them rebuild it. I'm hoping they get it done in time so my car isn't down any longer.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
