can I run this set-up without using a fuel pressure regulator
TheAButton
53
Jul 7, 2008
Selah / Yakima, Washington
Ok so I have a MAF translator with a 3" GM MAF, 550cc injectors, and I have a walbro 255lph fuel pump. So my question is that, can I run this set-up without using a fuel pressure regulator, I was looking to run about 16 pound, or what ever this set-up permits me to run. Any feedback would be nice thanks. I'm also running a 16g right now too.
It is recommended to get a afpr with the 255 walbro, but you can get away without it. I would recommed you get a wideband first though if youre on a budget.
mann, i am having the same problem. built motor running rich with 255 walbro. what do you all recommend for both of us and what is the good cheep afpr or fpr for both of us.
Not using an AFPR? That will make your motor run rich. What size injectors are you running?
Well i wouldn't go with a cheap "ebay" afpr. Fuel lab and aeromotive make good afprs.
Just like the guys above said. You could run with an afpr, but then what was the point of getting the 16g and 255 ? Might as well go the whole 9 yards and finish up, get the afpr, wideband, and tune it.
Otherwise you are just going to run poorly and kill your gas mileage.
I plan on running mine without a AFPR for a little while until I have the extra $200. But My mod list is up to date. Plus a certain vendor told me that they have done it to numerous cars with out problems.
I also remember seeing something on this site about flow rates with out rewire and it was like 195 lph or something like that.
Pimking can u elaborate on that, about flow rates without rewire on 6 bolt swap? right?
it wont matter if its a 6 bolt or not.
But the stock wire doesn't allow for all the voltage to reach the pump like a rewire would.
I can't remember the thread it was in but basically the 255lph pump flowed at something like 195lph on stock wires. Thats if I remember correctly.
so we would definitely need to upgrade our fuel pressure regulators correct unless we rewire. right?
a rewire will cause it to flow more. the stock wire will let it flow less.
I still plan on getting a AFPR it will just have to wait a couple of weeks. besides the car is in parts right now.
