can i disable my safc?
milby43
189
Aug 6, 2008
Laurel Springs, New Jersey
So my cars running nasty, no real low end power, and it hesitates in the low end. Like until powerband. The previous owner had some guy tune it without the a/f gauge.
So i was wondering if i could zero it out to just use the computer some how? Or even just zero out the percentages if that wouldn't hurt?
Any ideas?
Thanks a kaboodle
Andrew
Like 4lurker said, you can zero everything out if you are running stock injectors. I have my settings at zero, but I'm running a flashed ecu
yea i have the stock 450cc blue tops.
And im talking about zeroing out the hi and lo trims
Also what are your neo point intervals set at?
And what should my hi throttle low throttle break off points be set at if i want to zero out the safc?
Okay well im using the stock ecu from my car.
Im waiting on a wideband at the moment since my gauge is toasted.
I just wanted to basically run off my ecu.
And when i meant throttle break off points I meant where it would change between hi and lo throttle settings.
