Can anyone tell me what gauge this is?
Wow that is a cool concept. I think I might get that gauge, its pretty cheap too.
VEI Systems dual display gauge
The only place I could find it was on this site TM Tuning - the future of VW Performance Parts
but Im not sure if its only for Audi/VW cars. I would like to find one where I can integrate any wideband gauge. For example if you already have an Innovative or AEM wideband.
Got it! Here it goes and it says you use it with other widebands as long as you have the sender. And its not expensive at all, $89 for two gauges in one. vGauges
Just because Audi/VW folks use it doesn't mean it isn't going to work on our cars. It uses the LC-1 sender for AFR and a boost sender. I doubt it is going to work with an AEM, thats like trying to say I already have an AEM gauge but want to hook up a Innovate sensor/sender. Sure you can probably do it if you wire it up for it, but it isn't going to be plug and play.
So it is possible to use an AEM sender plug and play? I stand corrected!
It looks like for it to work with AEM you will need the AEM inline controller instead of the UEGO gauge with a built in controller.
My only question is how do you hook up a boost sensor/sender? Ive only used the regular mechanical boost gauge. Does it go from mechanical to electrical? Would I hook my vacuum line from my intake manifold like my regular boost gauge, but instead hook it up to the sender?
You hook a vacuum line to a sensor that you put in the engine bay, then run the wires from the sensor to your gauge. Simple.
I like that site that you linked, they have an option for orange. The site I was looking at is only blue/red. Orange looks like it would match our stock gauges pretty well!
its a air/fuel meter and vac/boost gauge, air/fuel on bottom and vac/boost on top
This was established in the first post my friend. We were trying to figure out what brand and where we could purchase it. Thanks though. LOL
and its a wideband?
Its just the gauge, you have to have an existing wideband... Innovative, AEM, etc. If you buy it from the site thats linked above they have it where you can purchase it along with the wideband.
and with the wideband do you mean you just have to have a wb or does it have to be the aem or innovative?srry but im really interested in these gauges.
For the boost you will need a boost/vacuum sender which is on the vGauge site and for the wideband you will need an Innovate LC-1, LM-1, PLX, etc. This comes straight from the description on the site. Im not sure if AEM works or not and if you don't currently have a wideband I would suggest the Innovate because it seems to be the best out.
