Can a turbo pressurize the crank case?
Sp1kE
376
25
Dec 24, 2005
stratford, ON, Canada
Is there anyway a turbo with a bad seal could send pressure down the drain line?
I thought my rings were gone, and had blowby as oil was spraying out of everywhere! Oil cap even blew off.
PCV is just venting, not hooked to IM.
Then I got descent Compression numbers of 150 across on a stock 6bolt.
Turbo is a HY-35.
Thanks
Here is an easy way to tell:
Do a boost leak test at the turbo inlet. If you get pressure coming out of the cap, dipstick and PCV then remove the UICP and do a boost leak test at the throttle body. If it still leaks you have bad valve seals. If not it's an internal turbo seal problem. It is normal to get a little bit by the seals when the car is not operating but too much air and it will be obvious.
    • george bromwell
    • pma1123
    • Sdcryan1
