Can A/C fuse box be removed???
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
I got rid of my A/C stuff. Condesor, compressor, etc. Can the a/c fusebox (located in the drivers corner by the strut tower) be removed? I dont have n A/C fan. I use my main fan though (the passenger side one). Will removing the fusebox disable the fan?
I always have the A/C button pushed so the normal fan will stay on contantly. So would I have to wire the fan to a switch?
You could probably wire up both fans with a relay to the stock switch ac button.
I am only running one fan. How would I wire it to a relay to the stock button? I think when I remove the fuse box the button will no longer work.
got rid of mine long time ago,took out the whole system and installed it in my other 1.8 that did not come with ac,been running one fan and no ac fuse box,never had a problem
