Camber Plates/eibach Springs
pbwu1f
222
Feb 27, 2009
West Palm Beach, Florida
im going to get some eibach springs for my 91 talon soon. im going with the pro kit, and just would like to know if lowering my car would eat my tires alot. i know that lowering your car eats tires, but just want to check if camber plates eliminate that. also i was looking at camber plates and whats negative camber and positive camber and all of those words that i may need to know. thanks
They make cheaper things like Camber bolts for the front that you can get at orielly's and rear camber bushings for the rear that you can get at extremepsi.
The camber drop is significant enough to cause your Camber to be out of factory specs. I'd just do the research and/or either buy the camber kit from Ingalls. They make factory and aftermarket kits for alot of makes and models, just like Moog.
When I say camber, I mean negative camber, so that means the inside edges of your tires will be worn more than your outer edges. Camber is viewed from the front of the tire. So, if you are looking at it from the rear (not side) the top will be inward and the lower inside will be outward.
  • Wanted 6 bolt NT water pipe
    • chrisman287
