Eibach lowering springs
konigtalon
40
Jan 5, 2006
morehead, Kentucky
Hey there im new here and was just wondering if somone could help me out. I have a 93 nt talon and just lowered it using eibach sportline kit and now in the passenger front side I have a lot of Klanking noise what is this from?
I think it might be the front upper shock bushing please let me know anything I can try thanks
What do you mean klanking ? Is it when your moving, or at idle ? Did you install them your self ? If not maybe go to www.Vfaq.com , and check under the suspension category, and look for 1G struts removal. After you see whats all involved, and what bolts pop your wheel off , and make sure everthing is tight. Make sure the struts have been seated correctly in the control arm. Theres alittle notch that must be in the center on the back side for everything to line up how its supposed to. Also remember your car is lower now so something could be hanging around down there getting knocked up a bit. GoodLuck
