Eibach Lowering Springs Part #34414A
gophishy10
350
7
Apr 17, 2012
Boston, Massachusetts
I found some eibach lowering springs on Craigslist for $50. Here's the , ad:
95-99 Eclipse Eibach Lowering Springs never used
Does anybody know if these are from the pro kit? I tried googling that part number and didn't come up with anything. The two numbers on the spring are 34414A and then 6014.001.
6014.001 is the part number for a 2g FWD, front.
6014.002 is for the rears.
6014.140 is the number for the complete set (all 4 springs) I believe.
I just asked the guy and he said it's all 4 springs. So the back two should have 6014.002 on them?
I hear there great they sell them on tire rack.com you could look them up.
make sure you get a camber kit!
As you go lower its going to put more cast ,camber ,tow you want to have your tires run and wear even!
Ingalls camber kit is what i used! It replaced the factory a arm mounts
Those are Eibach Pros. The pros are black and the sports are red. 50 bucks for all 4 is a steal, just make sure all the part numbers are correct and you'll be good to go. I have the Pro kit on my 95 gsx and the back was the only place I had camber issues. I used longer bolts and washers method. Just get an alignment and you should be ok.
Awesome thanks!
Yeah I grabbed them up last night and they all had the correct part numbers on them. I work at a toyota dealership so I'll probably just have them give it an alignment for me.
